My power supply is blocked at 28v
Michael476
Joined Jul 31, 2023
Hello everyone, I bought an electric machine to make some repairs smarthphone, but it is blocked at 28.6V and can increase to 50v
The problem is that I need a minimal voltage for telephone repairs, between 0 and 28V, how can I do this?
here are 2 photos to illustrate the problem, thanks for your help.
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
It appears that your power supply isn't working. Have you measured the output voltage to verify that it agrees with what's displayed?
Was it purchased new?
That model power supply P-3005D I thought has a maximum output of 30V 5A. Did you buy this new?
I would measure the output, check if the panel meter is just reading wrong.
AnalogKid
Joined Aug 1, 2013
12,268
but it is blocked
What do you mean by "blocked"? Do you mean that the output voltage cannot be adjusted below 28 V? If so, are both the coarse and fine adjustments turned all the way to the left?
Manufacturer / product web page / user manual / model number - ? Also, photo of the inside of the supply.
ak
Michael476
Joined Jul 31, 2023
Thank you for your reactivity, the output voltage is equal to the one displayed on the screen.
Yes, the power supply is new.
The knobs are turned all the way to the left, so it doesn't go below 28v.
Brand Sunshine model P-3005D
Michael
bertus
Joined Apr 5, 2008
23,005
It could be a broken wire or potmeter.
When the bottom wire or connection is open, the pometer can not work.
Bertus
35,171
Don't turn all the knobs counter-clockwise.
Set all knobs to mid-range.
You ought to see 0 on the CURRENT readout and somewhere around 15V on the VOLTAGE readout.
If you cannot control the VOLTAGE then the PSU is busted.
If you take photos of the top and bottom side of the control board I might be able to find the schematics.
AnalogKid
Joined Aug 1, 2013
12,268
Well, it clearly is a linear supply (not all of them are). If you had a schematic, we could work through this pretty quickly. The open pot connection is a good suggestion. It is suggestive of something that there still is adjustability in the obviously wrong output.
What is the output voltage range spec?
ak
BobTPH
Joined Jun 5, 2013
11,647
The Sunshine P3005D is an adjustable 0 to 31 volt, 5amp supply with a 220vac input.
Post #1 shows a 50 volt output in the first photo. Maybe the output transistor(s) is shorted.
I am thinking the voltage feedback network is broken, that is why I suggested a small resistor, which might change things if I am right.
BobaMosfet
Joined Jul 1, 2009
2,211
A power supply like this is designed for a load. It will not give you a valid voltage reading without an actual load within it's engineering spec. Put a load on it, and see what it reads.
AnalogKid
Joined Aug 1, 2013
12,268
Why do you think that? Which portion of the schematic, or what aspect of the circuit topology, needs a minimum load?
ak
