My led lamp doesn’t light, why?
LesJones
Joined Jan 8, 2017
4,544
The push button will probably still work as a switch but the LED will not light as you have destroyed it.
If you connected the LED with the correct polarity and no current limiting resistor you will have exceeded the forward current rating. If you connected it with the wrong polarity you will have exceeded the reverse voltage rating.
Les.
