I would still add a few vias. Helps ensure a good ground on both sides. Your current connections are the plated through holes. Besides, make the board house work for its money.Okay so I created a pour on the back too and that solved the problem without vias.
So otherwise. Does the board look okay now? perhaps ready to manufacture?![]()
And by that you mean to check that all tracks are connected to the right pins/places?One thing - if you use small clearance for copper you want to sure is the solder mask correctly generated. You can check that with some gerber viewer, with Kicad Gerber viewer or with some web hosted one. I check gerber files (each layer) every time before ordering actual PCB-s.
