thank you sirIt looks like you have blobs of solder on the input capacitor to the regulator shorting the input and output of the regulator to ground. There is also a very large blob of solder on one wire shorting the regulator output to ground . The output capacitor also looks like it is inserted with reversed polarity. It would help if you posted the schematic with components numbered so we could say for example C1+ instead of input capacitor. Your soldering is so bad around the rectifier diodes that I can't see the tracks.
Les.
