My carrier signal is masked by my input signal.
demgaines
Joined Aug 14, 2008
I am using a NTE 1442 as a balanced modulator, but my carrier signal is being reduced to almost zero, my carrier is 100khz and my modulated signal is less than 15Khz. How can I adjust my circuit to have my carrier amplified and my input signal modulated onto it?
Audioguru
Joined Dec 20, 2007
11,248
I think an NTE part is a part from a major manufacturer but is re-labelled. Then the NTE datasheet does not have any of the details of the original part's datasheet. It is too bad that you did not use an original part that has a detailed datasheet.
38,952
It's doing exactly what it's supposed to do.
For Wikipedia:
A balanced modulator mixes the audio signal and the radio frequency carrier, but suppresses the carrier, leaving only the sidebands. The output from the balanced modulator is a double sideband suppressed carrier signal and it contains all the information that the AM signal has, but without the carrier.
If you want standard AM modulation with the carrier retained, then you need to use a multiplier or square-law type of modulator that varies the carrier amplitude in response the to amplitude of the input modulating signal but maintains the carrier with no AC input signal.
This can likely be done with the balanced modulator by adding a DC term to the input (such as by capacitively coupling the signal and adding a DC voltage at the cap output).
This DC will retain the carrier even when there is no AC signal on the input.
DickCappels
Joined Aug 21, 2008
10,661
If you post a schematic of your circuit one of us will probably be able to point out a way to unbalance your modulator. The test circuit below from the datasheet to which GopherT linked might give you an idea of how to do that.
Audioguru
Joined Dec 20, 2007
11,248
One function of a balanced modulator is to make voices sound "scrambled" so that nothing spoken can be understood by somebody listening on an ordinary AM radio without having the circuit (another balanced modulator) that injects a carrier into the received signal and detects one sideband. Without injecting a carrier into the received signal then the scrambling causes low audio frequencies to become high and high audio frequencies to become low then words are completely unintelligible. Also without transmitting a carrier then transmitter power is reduced.
