My calculated and simulated values for operating point not matched, why???
valorous
Joined Oct 28, 2021
18
I have used transistor 2N3904 having beta value (= 300) . My value for op are (5V, 7.5mA) but i m getting around (4.33V, 7.66mA). I am bascially simulating the fixed bias config of transistor by varying the beta value.
35,145
No two transistors are the same. The actual value of beta will be different. Your simulation might not model the part exactly.
35,145
My point is, simulation might not model the real part exactly.
Your simulation shows the cursor position. It does not fall exactly on the load line.
valorous
Joined Oct 28, 2021
18
o
ok,but it can be clearly seen that operating voltage is less than calculated(5V).
is this error valid or should i do something?
valorous
Joined Oct 28, 2021
18
How did you calculate the op?
i used the standard formulas...
like first i calculated Ibe by applying kvl in the base-emitter loop then using beta and Ibe, I found Ic. then I apply kvl in collector emitter loop, using the relation between Vce and IcRc and Vcc, i found the Vce.
ericgibbs
Joined Jan 29, 2010
21,567
I don't get it, what u mean by the standard.bjt?
and what are these graph saying.....can u please explain me in detail...
hi,
The standard.bjt are the bjt files in your LTS folders under lib/cmp.
The plots are showing there is a spread in the parameters for a particular transistor type.
E
valorous
Joined Oct 28, 2021
18
hi,
E
what does it mean by spread in parameter?
r my graph were correct or wrong ?
Papabravo
Joined Feb 24, 2006
22,111
A couple of points:
  1. The BJT model parameter "BF" is NOT the Beta value, it is the "Beta Factor". It is part of a calculation that will determine the actual performance in the simulation.
  2. It seems suspect that you are using the Letter B for two different purposes, in both the .step and the .measure statements.
I quote from the LTspice Help pages:
.MEASURE -- Evaluate User-Defined Electrical Quantities
.MEAS TRAN res6 PARAM 3*res1/res2
Print the value of 3*res1/res2. This form is useful for printing expressions of other .meas statement results. It's not intended that expressions based on direct simulation data, such as V(3), are present in the expression to be evaluated, but if they are, the data is taken from the last simulated point. The result will be labeled res6.
valorous
Joined Oct 28, 2021
18
A couple of points:
yes, in .step i vary the beta value and in .meas i want to find the value of Ic for different beta values.(spice error log file)
Papabravo
Joined Feb 24, 2006
22,111
That is not what your statement is asking the simulator to do. You apparently did not read the LTspice Help file with much diligence. See my edit to post #15 as I was curious enough about your intention. Beta and Ic(q1) are NOT the same thing. The calculated value of Beta at any point is the instantaneous collector current divided by the instantaneous base current.
valorous
Joined Oct 28, 2021
18
What are these values then??
i was assuming it the value of Ic at operating point for the corresponding value of beta.
