Mutual Inductance (circuit analysis)
full
Joined May 3, 2014
225
Hello everyone,
In this circuit there are two points (Mutual Inductance) ...
How I know the V1 is negative or positive and the V2 is negative or positive (please explain )?
This video explain how I Know when mutual is negative or positive .... but the loop I think wrong...:(
thanks,
38,804
That video is wrong. The red dots on the transformer indicate relative voltage polarity. A positive time-varying voltage applied to the dot input on one side (designated as the primary) will generate a positive voltage at the dot output on the other side (designated as the secondary). That means the current on the input is flowing into the dot (for a positive going signal) at the primary but flowing out (not in as the video seems to state) from the secondary output to the load.
