Multiple Input/Output Voltages with a single PLC
Riaan Pretorius
Joined Oct 29, 2017
8
Hi everybody,
I want to know if it is possible to use a single PLC with multiple input and output voltages on a single PLC. Since the inputs and outputs are grouped, can I connect 120VAC and Neutral to a spesific group and then 24VDC and 0VDC to another group, enabling me to get inputs and outputs of both AC and DC voltages on a single PLC?
The PLC in question is the Mitsubitchi FX5U-64-MR/ES, it is a relay output type.
Thanks in advance
MaxHeadRoom
Joined Jul 18, 2013
30,854
I would place the Neutral on one side of the load and switch the live conductor with any fuse in the live side, for safety.
Max.
