Hi there!
I need some help with a complete design for aquarium lighting.
I've been researching, and i know I can do this with Arduino, but I want to build a complete and specific solution for my project.
I want to do the following:
Thanks for your advice!
- I will use a multi channel LED, 50 W, 4 channels, 750 - 1000 mA each.
- I want to dim each channel separately and timer controlled. I want to dim with PWM, since I learned it's the best for the LED and the color temperature.
- A temperature controlled fan, higher the temperature in heatsink, higher the fan.
- A LCD to view the time and time setting.
- Buttoms to enter the time data and dimmer adjust.
