MT7865 led driver - PWM dimmable APFC BUCK LED Driver
kzsolt87
Joined Jul 13, 2023
23
Hi
I removed a small PCB from a bathroom led light which has this MT7865 led driver IC. I tried to google it or look for examples to understand how does it work or what kind of configuration available, but the only thing I can find is a single page "datasheet".
https://www.alldatasheet.com/datasheet-pdf/view/1134573/MAXIC/MT7865.html
Any idea on this? Btw, the leds are gone in the light, so its just for fun / to learn.
Thank you
Irving
Joined Jan 30, 2016
5,195
What is it you want to know? The datasheet fully describes its operation and shows a typical circuit using rectified AC mains to drive a local switch-mode constant-current power supply for the LED, which can use a pulse-width modulated signal (PWM) to dim the LEDs (from a separate controller, may not be used in a bathroom light).
kzsolt87
Joined Jul 13, 2023
23
Hm, okay.. but for example how do I know what is the current its going to supply? Can it be changed? Can it drive a single led for example?
I kinda start to get your point given its a constant current power supply so measuring voltage on the output without load doesnt make much sense.
ronsimpson
Joined Oct 7, 2019
4,805
Sad data sheet. data sheet
MAXIC
Rs measures the LED current indirectly. There is a MOSFET from DRAIN to CS. When a PWM cycle starts current flows from C7 through the LED, L2, MOSFET and Rs. The on-time stops when the voltage across Rs reaches some (unknown) voltage. Maybe 1V.
The on-time is set by how long it takes to charge up L2 to the desired current. I do not know the frequency maybe 60khz to 200khz. (internal oscillator)
Note the PWM pin, has a frequency set by an external computer. Probably 100 to 1000hz. This is for dimming, not current control.
