Anyone have a link or reference to using Pickit 3 and MPLAB IDE to Pgm using a HEX file only?
Max.
Max.
I will try that.(Assuming MPLAB, not MPLAB X) Start MPLAB with no project loaded. Select target processor, and select and configure programmer. In File menu, select "Import..." Navigate to the .hex file you want and click Open. Then proceed to program.
That's my recollection, anyway. I last did it quite a while ago, but I think that's all there is to it.
The mplab_ipe application was designed for this.Anyone have a link or reference to using Pickit 3 and MPLAB IDE to Pgm using a HEX file only?
Max.
