got download them but still errorIt's saying those files are not in the project directory. Did you download them?
You need to put it in the PHYSICAL directory.. Just because it shows in the build tree doesn't mean its in the right place.
[/Q
what mean by physical directory ? the c file is inside the folder
Thanks, bro I readd the file done alreadyView attachment 291152
The yellow triangle states the file is missing..
| Thread starter | Similar threads | Forum | Replies | Date |
| M | Build Problem MPLAB v6.20 | Software & IDEs | 1 | |
| A | mplab ide build fail error (makefile) | Software & IDEs | 0 | |
MPLAB X IDE code clean & build | Microcontrollers | 11 | |
| B | MPLAB BUILD FAILED (exit value 2, | Programming & Languages | 7 | |
| M | MPLAB build problem | Programming & Languages | 1 |
