MPLAB X IDE code clean & build
cmartinez
Joined Jan 17, 2007
8,860
I've been working with MPLAB X IDE v5.35 for a while now, and have finally gotten used to its, let's say unusual, environment.
I haven't upgraded it to a more recent version because this was the last version that includes the MPASM assembler. I intend to eventually upgrade to the new assembler in the near future, but that's another story.
Anyway, I have two questions:
  1. What's the difference between "building" a project, and "cleaning and building" it? ... and I mean other than hygienic.
  2. I'm having some trouble debugging a subroutine that is supposed to match a string received through the serial port (and stored in ram) against one received through the UART. Is there a way to simulate the procedure?
Ya’akov
Joined Jan 27, 2019
10,301
“Clean“ is like “make clean” when using a makefile. It removes all the output from a previous build so it won’t reuse files that were generated by it.
Sorry to say I can be of no help on your second question.
atferrari
Joined Jan 6, 2004
5,029
For each micro you should check what peripheral may be simulated. I never did peripheral simulations.
MCHP insists on doing "simulations" on real hardware situation.
Make and makefiles are extremely useful in larger software projects with lots of files. I often keep individual function build dates embedded (during the build process that uses 'Make') in the C headers for various device modules used in a project to track software modifications.
C:
// main.c
static const char *build_date = __DATE__, *build_time = __TIME__;
// bmx160.c
// code
void bmx160_version(void)
    printf("\r--- BMX160 Driver Version  %s %s %s ---\r\n", BMX160_DRIVER, build_date, build_time);
// mcp2210.c
Each data-time is a static const var that gets set during that source file recompile.
Just Build:
Build Clean:
MIS42N
Joined Jan 25, 2013
22
Some PIC processors, compile for debugging, program the processor with say a PICkit3, then run the code on the processor in real time with check points, memory maps, etc. I didn't know how to get the right timing for UARTS in the simulator, then I found I could do it live so didn't look further.
MaxHeadRoom
Joined Jul 18, 2013
30,810
I am faced with the same issue due to V 8.92 not supporting the later pic's,
Did you find any support or instructional that helped in the transition to MPASM X ?
cmartinez
Joined Jan 17, 2007
8,860
Not sure what you mean. I didn't start working with Microchip's products until about 4 years ago. And during that time they "upgraded" their assembly in such a way that made my code incompatible with their later version. Their changes in syntax and structure are so significant that I've been waiting until proper translation tools (perhaps by a third party?) become available before taking the leap.
MaxHeadRoom
Joined Jul 18, 2013
30,810
I still use the original MPLAB IDE 8.92, which was aimed totally for assembly programming. MPASM.
When Microchip went to the X version, they started moving away from ease of assembly and began mainly concentrating on C.
The reason I am having to try and get familiar with using the V5.35 X is that I need to use one of the latest pic's that has a feature previous versions did not have, so IDE 8.92 does not support it.
Anything after X ver 5.35 changed the MPASM approach completely.
cmartinez
Joined Jan 17, 2007
8,860
I have in my to-do list the task of learning Microchip's new assembly format and syntax. And possibly find or write a tool to help translate my old code to the newer version. But that's going to happen only in my next simple project. That way I can get started without compromising my work.
Sensacell
Joined Jun 19, 2012
3,787
Had the same troubles, I feel like Microchip dumped me in a drainage ditch and drove away laughing.
MaxHeadRoom
Joined Jul 18, 2013
30,810
Do you have a copy of the MP-MASM 8.92?
If your IC is within the scope of this version I would use this pgm. over any of the others.
