MPLAB BUILD FAILED (exit value 2,
Batt Vac
Joined Sep 17, 2017
5
Could someone give me some direction of this issue. I had a program built by a company and they have me programming my pcb's with MPLAB. My problem is that all of a sudden I'm getting a build failure errors and have no idea why. Unfortunately I'm not a programmer and they didn't go in depth on this with me but when nothing has been changed I just cant understand why or how to repair this issue. Would really appreciate so advise.
Maybe you should use the mplab_ipe to program the boards with a precompiled hex file.
http://ww1.microchip.com/downloads/en/DeviceDoc/50002227C.pdf
Your error is caused by "main" being seen twice by the compile process. It looks like maybe a stray file called 'newmain.c' is in the makefile now. Open the Projects menu -> DentsDings -> Source Files to select files to examine for a dupe 'main' function. If you're not a programmer this might be confusing.
Example Project menu view:
There is a 'main' function in the pat.c file in this example.
Batt Vac
Joined Sep 17, 2017
5
Zip the project up and post it I'll have look at and help but would need the project.
That's fantastic that you offered to help me out! Thank you very much! I worked all day on it yesterday and somehow I was able to get rid of the errors. I had my pcb maker upgraded the vacuum sensor on the board to a stronger one that's from the same company and same style and its not programming the sensor on when to power off and on. Would you be able to look at the programming on that to see why or would that be something completely different? I will post whatever we need if that's something that might be in the program. That question that I'm asking shows just how little of education that I have on the programming side with my product. I'm just trying to build the best product for everyone that I possibly can.
be80be
Joined Jul 5, 2008
2,395
Zip up the project and I could look at it Mplab - x can be a pain. But it's hard to post all the files it makes now for you
and from your pic looks like it's added some from somewhere else.
Batt Vac
Joined Sep 17, 2017
5
Do you want me to just zip up the MAIN.C file and post it?
