Mouse repair - power to circuit board, but not powering on
knightfork
Joined Sep 11, 2013
27
I have a Logitech MX Anywhere mouse, and the microswitches on these are notorious for failing. The rest of the mouse is great, so I went ahead and purchased new microswitches on ebay and soldered them in.
Repair looks pretty much like this:
Getting the old switches out wasn't easy as I don't have hot tweezers. I think it's possible I may have damaged the mouse's circuit board at this stage. Soldering in the new microswitches was easy enough.
Problem I'm running into is that the mouse doesn't power on.
When I check the voltage at the connections of the batteries to the circuit board (highlighted via arrows in below pic), I get 1.24V for each battery with the power switch off. With power switch on, I get 1.17V. But the 'ON' LED doesn't turn on and the mouse isn't recognized by the mouse's wireless receiver (which is plugged into computer).
Is there anything relatively easy to check here? It's a mouse, so not worth sinking a lot more time into this, but wondering if there's something obvious to look for.
I guess worst case, I can look to buy a similar mouse with worn out microswitches for cheap on ebay or craigslist and move the new microswitches over.
wayneh
Joined Sep 9, 2010
18,100
Grasping at straws: Power switch?
You could remove the switches and clean up the pads. It's possible you shorted one somehow. It should power up without the switch on the board.
knightfork
Joined Sep 11, 2013
27
Worth a shot, but no luck. Removed the microswitches, but the mouse doesn't power on.
I suspect I damaged something when I removed the original microswitches with only one soldering iron (and no hot tweezers). It was a bit of a hack job and I may have overheated some nearby parts.
geredelulu
Joined May 7, 2024
Sorry if i resurrect this thread in the hopes someone has the answer to this. Does your mouse have 2 circuit boards connected together via flex cable? I encountered this --- but when I unplug the flex cable the mouse turns on as normal - then i plug the flex cable and it works like normal again. But then after turning the mouse off for a while again the mouse would not turn on and I have to do it again.
Is it possible that the two boards have become "unpaired" with each other? Has anyone found the fix?
