Sorry managed to measure the wrong pin. Collector is at 0vYes. Collector is at 12v
Blue is bottom trace, red is topSounds like Q1 is shorted
Are the blue traces on the bottom side of the board
I think we have a winner, the cap is the reverse of the footprint oddly. I will remove it tomorrow and reinstallpin2-6 needs to charge up to 8 volts to switch the output of the 555.
Check C3 and make sure it's installed correctly as far as polarity.
That is the normal operation not sure why it wouldn't do that on the breadboard.The only slightly unexpected result is that the pnp doesn't turn off when the load is disconnected from the collector. Instead it continues pulsing the 7555 pulses, I expected it to pull back up to the battery voltage, which the breadboard version does.
I thought that would be the case but was just confused as the breadboard version sat with the collector and emitter at 12v when the load was removed. Either way it won't cause issues due to the load being connected via a switch.That is the normal operation not sure why it wouldn't do that on the breadboard.
| Thread starter | Similar threads | Forum | Replies | Date |
Motorcycle turn signals and relay question | General Electronics Chat | 6 | |
| L | LED Flasher Help | Digital Design | 20 |
| Similar threads |
| LED Flasher Help |
