I just need someone to verify that I'm completing my assignment correctly. I have not yet included line and cross-reference numbers on the diagram so disregard that i'll work on it later. This is what needs to be included in my ladder diagram..
A 3-phase motor is to be protected against phase loss, phase imbalance, or low voltage using a Square D MPS type relay. The motor is to be controlled from a START/STOP PB station that also contains a green pilot light to indicate the status of the MPS relay. The MPS is to be supplied power form the line side of the starter. Include line and cross-reference numbers on the diagram.
The green status light should be ON when the 3-phase, 240-volt motor circuit and the MPS are energized. The motor is not to be started unless the status light is illuminated. This ON status indicates that a phase reversal has not occurred in the circuits on the line side of the starter.
Available equipment list:
Motor starter
- With holding contacts - 240 VAC coil -1NC/1NO Aux. contacts
- With 12 VDC green light
240/480 x 120/240 V transformer
MPS relay with 240 input
120 VAC to 12 VDC power supply
- With battery backup
Control relay – 12 VDC
- 2NC/2NO sets of contacts
Motor starter
