Motor speed pulsating
riccardof
Joined Oct 3, 2017
I have a threadmill motor controlled via an mc2100els-18w. Suddenly it started driving the motor in pulses, and even if I try to increase speed it goes up but always pulsating. Any idea what to look for?
MaxHeadRoom
Joined Jul 18, 2013
30,658
Is the motor on the T.M. or on a separate application?
If it is using the pulse wheel on the motor, this could be part of the problem.
Max.
riccardof
Joined Oct 3, 2017
Max.
Thank you for your reply... no it is still fitted to TM. IMO the LED flickers normally. In the video I was trying to set calibration but the speed fluctuates due to the behaviour of the motor... in the other video listen to the motor trying to increase speed... [videos]
strantor
Joined Oct 3, 2010
6,875
not a bad commutator section.
Not sure what the problem is but I suspect there is an uneven mechanical load; something wrong with the belt in a certain spot that makes it have to try very hard in the same place every time. try tuning it by hand and see if there is spot that is hard to turn.
riccardof
Joined Oct 3, 2017
No uneven mechanical load for sure. I’m pretty confident it’s the controller board... but don’t know where to start from, capacitors? PWM controller?
strantor
Joined Oct 3, 2010
6,875
remove the board and look it over both sides. look for burnt spots. Look for capacitors that are puffy. Look for exploded components
