Motor run capacitor wiring
nivekau
Joined Jul 20, 2023
I'm aware that motor run capacitors do not have any polarity, however I have a Ducati 4uF 460v cap that has a brown wire and a blue wire coming out of it. Why are these wires coloured if there is no polarity?
The cap I am replacing had two orange wires running to it, one of which was marked with a 'C' label, presumably meaning 'common'. Do I connect the 'common' wire to the blue or brown wire on the replacement cap?
Ian0
Joined Aug 7, 2020
13,311
A motor run capacitor can also be a power factor correction capacitor, which is connected directly across the mains, and that would explain the colour coding.
It is a non-polarised capacitor (because it can be connected to AC) so can be connected either way round,
prepka
Joined Oct 5, 2020
34
The blue wore is considered to be neutral (common) and the brown is considered to be the hot as that is the color coding in Europe. the wire marked C is considered to be the common so connects where the blue was and the other lead will go where the brown was simple as that
MaxHeadRoom
Joined Jul 18, 2013
30,881
A capacitor used as a start or run capacitor is in series with the start/run winding.
whether oil filled paper or dry electrolytic-bi-polar. 'polarity' does not matter.
