Motor control question. No experience. Instuctables project.
MaxHeadRoom
Joined Jul 18, 2013
30,795
What is the No. of the controller? MC60?
You cannot use a capacitor on this controller, do you have the series choke for the motor, this helps somewhat.
The PWM controllers are better, MC2100 etc.
Also are you using the flywheel?
Max.
Syncman
Joined May 10, 2019
7
Using the flywheel. The controller is the one described below. Tried posting the link, but not allowed. Amazon.The cap would be on the rectifier bridge output.
uniquegoods AC 220V 10000W High Power SCR Motor Speed Controller Voltage Regulator Dimming Attemperation Thermoregulation Board
MaxHeadRoom
Joined Jul 18, 2013
30,795
OK that is a simple Triac with a bridge follower, quite a bit cruder than the MC60 or the KB style SCR bridge type.
Not a very good application for a DC spindle motor.
Max.
