Motor capacitor?
sirch2
Joined Jan 21, 2013
1,071
Sorry, didn't know which section to post this in...
I have a workshop dust extractor that keeps tripping the RCD and having taken it apart it looks like the capacitor has started to break down. The capacitor is one of these - https://uk.rs-online.com/web/p/film-capacitors/0238299
Anyone know a suitable alternative since that is discontinued? I'm in the UK, 240v 50Hz, that cap has 3 terminals is marked
0.1uF (x2)
0.005uF(y)+0.005uF(y)
I've looked on ebay etc. but not found anything similar. How critical is the capacitance, could I use different values?
MaxHeadRoom
Joined Jul 18, 2013
30,773
The critical part is it should be motor start rated, although those values look awful small for motor start caps.
Can you give any details on the motor?
shortbus
Joined Sep 30, 2009
10,049
That motor like most similar vacuum motors is a universal motor, they don't have or need start capacitors. Your motor has brushes, again like most dirt/dust vacuums. Your caps must be for something else.
That said, many times RCD's have a hard time dealing with brushed motors. RCD's have a finite life time, after a number of "trips" they trip at a lower set point. So your RCD would be where I would look first, not the motor caps.
sirch2
Joined Jan 21, 2013
1,071
Thanks guys, the capacitor looks a bit dodgy and that is the thing that trips the RCD so I've ordered the one linked above.
