ooopsss...See post 15.
it's going to be much harder to devise something with an axial turbine, instead of a traversal wheel, as I had originally visualized it...
The curved vanes might make opto-interrupting tricky - and that colour molding might make opto-reflective just as difficult!See post 15.
I'd probably just change the thing for a paddle wheel type, instead of putting too much work in this one.The curved vanes might make opto-interrupting tricky - and that colour molding might make opto-reflective just as difficult!
This would be my choice short of getting into more expensive solutions like flow switches and sensors. With all the inexpensive stuff falling off the boats from China I have yet to see inexpensive flow stuff fall off the boats.http://www.amazon.com/gp/product/B0..._m=ATVPDKIKX0DER&pf_rd_r=0K8AKGXN9XEEV2NA6WV0
It would be quite easy to use a simple light source and sensor mounted on opposite sides of a flow paddle like the one in the link. Yours is a little more difficult, but might be done.
That's actually a very good idea... another possibility would be to drill a hole in each vane so that a light could be shined through them at an optical sensor on the other side...It looks like it dismantles pretty easily, if so I would look at embedding a miniature button magnet in one of the vanes and use a prox detector on the outside, I don't think the rpm is going to be that high to worry about imbalance, but if so another magnet could be used on the opposite vane.
Max.
Yes, they can do exactly what you want. Just make sure they're the size you want and are capable of detecting the minimum flow you need. And that they also work at the proper pressure rangeI found these on ebay and wonder if one of these can work for what i want? http://www.ebay.com/bhp/water-flow-switch
You mean there is no water in the pipe when the pump is turned on?Hi Cmartinez the problem i see using the magnetic water flow switch is that when the pump is turned on
it takes about 15-20 seconds before the water reaches the flow switch.
and close the contact.
so the alarm will then be on.for that time so i will need a delay of power for that 15-20 seconds before the flow
switch is closed.
i found a delay power supply on ebay.
can this work? http://www.ebay.com/itm/12V-Power-ON-delay-relay-Module-Delay-circuit-module-/400494540934?
or is there another way of doing this. not sure if i have this right
thanks Paul
Then that means that @AnalogKid is pretty much on the mark... about three 555's will be needed.Cmartinez yes that is it correct
paul
Yet another possibility would be to monitor the pump motor's rpm, which are bound to be higher if the motor is running on dry. Or maybe also monitor how much power (in amps) is being consumed. If the pump is running on dry, then RPMs would go up and Amps would o down.As most of these W.C. spindles are 3ph, I am guessing that you also have a VFD?
If so, you could look at incorporating the various I/O such as instead of a 20 sec delay, use an up-to-speed output signal to AND with your flow meter Normal condition and either inhibit motion and/or shut the VFD off, this also could monitor it when running.
Max.
