analogdesign
- Joined Aug 29, 2013
- 14
Ian,In saturated region its either on or off, so there's either lots of current and very little volt drop, or no current and all the volt drop - either way P=I*V dictates that very few watts are dissipated,
In linear mode the device can simultaneously be dropping significant voltage and carrying significant current I*V gives you the resulting watts.
I think you're a bit confused here on terminology. You're mixing up linear and saturated.
In linear mode the device is a switch and the current through the device is found from Ohm's law: I = V/R or V*gm in this case.
In saturation the MOSFET is acting as an amplifier. The output impedance is high (ideally infinite) and the power is I*V. In this case the MOSFET most certainly does not follow Ohm's law, since ideally, as long as it is in saturation, the current is constant (it is set by Vgs alone).
