Ok, i get the nonlinearity idea. The low resistances you mean here is referring to miliohms range, which is the Rds(on) value shown in specification right? Per my understanding, the Rds(on) is occurring in saturation region. Is the my previous simulated resistance which is in kΩ range or the IRF3703 resistances on the order of thousands of ohms as you have mentioned operating in linear region? When we are biasing the MOSFET at different Vgs AND without Vds biasing, are we operating the MOSFET in linear region (left region of dash line) as shown in IV Curve.png? Please be patient with my simple questions as I am trying to make myself clearYou change the resistance by changing Vgs. For low resistances, the resistance would not be a function of current, except to for the nonlinearity of the FET (there will always be some nonlinearity, even in the "linear" region).
You can use a FET as a VCR, but each unit will require a different Vgs to get a given value of resistance, so it would not be suitable for production.
Some people use JFETs in this application, but they are generally in a feedback loop, where the resistance value is servoed to accomplish a function such as automatic level vontrol.
JFETs are small-geometry devices, so their resistance is higher, which I think might be better for your application. If you use a switching MOSFET such as IRF3703, I think your resistance will be extremely nonlinear if you try to attain resistances on the order of thousands of ohms. If you are looking for milliohms, you should be OK with the power MOSFETs.
