Confusing, at least.That would look interesting when you put your hazard/warning lights on it would look like party lights with each indicator slightly out of time with the others. I don't think that would be legal.
Lost count of the number of times I took a vehicle to a dealership with some check engine indication, had them scan it for about $100, and say nothing was recorded.I think you see this from the wrong angle. As a semiconductor specialist, I've worked with automotive companies for many years, and the engineers are in no way averse to using new technology, and the slur about "built in failures" I can not recognize.
Did it end up being the 'security system'? My oldest son had the same problem, no crank. Let it sit for ~1hour unlocked and it would start.Ended up unplugging the 11 pin connector on the security box and no problem since.Lost count of the number of times I took a vehicle to a dealership with some check engine indication, had them scan it for about $100, and say nothing was recorded.
Lost track of the number of times my '03 Explorer wouldn't start (no crank) before the problem could finally be isolated. There were half a dozen things that could cause it to fail. I got so tired of paying $100 for a "no problem" diagnosis that I made them print diagrams for anything that could cause the problem and started eliminating them one by one. It would always start in the service department but it was my Wife who was getting stranded most of the time.
I had a similar problem with my jeep, I was able to read the flash codes and it kept telling me the idle control sensor was the problem. After weeks of stuffing around I finally found worn wiring under the dash that was intermittently earthing out the signal wire for that sensor.Lost count of the number of times I took a vehicle to a dealership with some check engine indication, had them scan it for about $100, and say nothing was recorded.
You can also buy a nice scan device for under $20 now. You connect to it with your smartphone or computer via bluetooth or wifi. You can get far more information than those auto parts store scanners, unless they've been upgrading.FWIW a lot of auto parts stores (Autozone and others here) will scan your heap for free and give you a printout. It's not always a complete diagnosis down to the bad part but it will you what it's thinking.
That was high on my list of suspects, but the dash indicator wasn't flashing fast. Good to know if it starts acting up I can just disconnect a cable.Did it end up being the 'security system'? My oldest son had the same problem, no crank. Let it sit for ~1hour unlocked and it would start.Ended up unplugging the 11 pin connector on the security box and no problem since.
Know of a source for wiring diagrams/schematics? I have a complete set of troubleshooting docs, parts diagrams, part numbers, etc for both of my BMWs; it actually covers most models...You can find most trouble shooting codes online and how to pull them from the car. Without having to pay the dealership.
http://www.troublecodes.net/ford/
This site have a good list http://www.carenginediagrams.comKnow of a source for wiring diagrams/schematics? I have a complete set of troubleshooting docs, parts diagrams, part numbers, etc for both of my BMWs; it actually covers most models...
Thread starter | Similar threads | Forum | Replies | Date |
L | MOSFET - can't control DC Motor | General Electronics Chat | 23 | |
C | Driving motors with atmega | Digital Design | 10 | |
TL072 LT Spice Model | PCB Layout , EDA & Simulations | 4 | ||
Demodulator circuit | PCB Layout , EDA & Simulations | 0 | ||
Increase Input Frequency circuit | General Electronics Chat | 13 |
by Jake Hertz
by Jake Hertz
by Duane Benson
