MOSFET Switch Design
aaa11
Joined Aug 16, 2023
I have two devices communicating via UART. Device 1 sends data to Device 2 through the same TX pin used by the MCU. I want to implement a switch to control the flow of data between Device 1 and Device 2. When the MCU needs to communicate with Device 2, the switch will be turned off, cutting off the data stream from Device 1. After the MCU finishes communication, the switch will be turned back on to resume the data flow from Device 1 to Device 2. What is the most reliable design to use for this switching mechanism.
Thank you,
ElectricSpidey
Joined Dec 2, 2017
3,346
" What is the most reliable design to use for this switching mechanism. "
Probably some sort of Tri-State bi-directional line buffer type of component.
BobTPH
Joined Jun 5, 2013
11,595
A reliable design would somehow inform device 1 that it should stop transmitting instead of just throwing away the data.
