MOSFET Squarewave amp
welkin87
Joined Nov 18, 2010
32
Due to my lack of experience in choosing MOSFET's, I am in need of some suggestions. I am working a small part of my senior design project.
Incoming signal:
- 10 MHz squarewave
- 25mA (at most)
Needs:
- voltage swing roughly -3 to +3 volts (two power supplies)
- up to 500mA constantly
The graduate student I'm working with suggested using a MOSFET and 2 power supplies: +3V and -3V. He already has a non-inverting opamp circuit doing what he needs, but he has me looking for an alternative. My idea was to use 2 cascaded common-source amps then a final common-drain stage.
Any suggestions on MOSFET's to use? There are so many out there and I need to find one so I can model it in LTSpice.
mcasale
Joined Jul 18, 2011
210
I assume the output is also a square-wave?
If you use an op amp for this, make sure it's spec'ed for the high frequency - 10MHz is sorta-high. Also, selection of the dual power supplies will depend on how close to the rail(s) the output can go. It's all in the spec sheets.
Why not use a dual supply comparator, like an LM311? Same rules apply about frequency and rail-to-rail outputs.
A discrete MOSFET design should be pretty straight-forward.
Go to a distributor like DigiKey or Mouser and search for whatever parameters are important.
welkin87
Joined Nov 18, 2010
32
Yeah, we need to output a square wave as well. 10MHz is much higher than I've ever worked with.
I've never worked with a voltage comparator before. I've only completed my junior year in electrical engineering; just started my senior year.
The graduate student had already designed the opamp and wants something else. That's what I'm left with doing, so another opamp isn't an option.
Will my DC drain current need to be 500mA to get an AC current of 500mA? What kind of specs at Digikey do I need to look for on a MOSFET?
mcasale
Joined Jul 18, 2011
210
Well, a comparator is like an op amp, only different :) It's output is only HIGH or LOW, and those values vary with the supply voltages.
For the MOSFET, you can run it like an "open-collector", except it's an "open-drain". This depends on how you connect your load. Can you post a schematic showing what you are trying to do and what you are driving?
For switching applications, which are not linear, the vendor may specify switching times, or maybe something else. You will want to look at FAST or Ultra-fast FETs because different vendors call them different things.
Same with the comparator - I don't know if an LM311 will work at 10MHz, but this is an old part. There's probably something newer that will work.
Where are you attending school?
mcasale
Joined Jul 18, 2011
210
If you decide to go discrete, here's a useful web page for calculating the bias points on a "cascode" BJT amplifier. You don't need to use FETs if you find BJTs easier to understand.
http://www.daycounter.com/Calculators/Cascode/BJT-Cascode-Calculator.phtml
Years ago, I used a circuit like this as a buffer amplifier for a 40MHz oscillator in a real product. So if you get decent high speed transistors, it should work fine. You can then clamp the output signal to whatever you want with zeners, or whatever.
The output stage can still be a FET depending on what you are driving.
Good luck.
welkin87
Joined Nov 18, 2010
32
Ok, met with graduate student today and he clarified some things. Pretty much, I need to take a 0 to +3V square wave signal and make it a -3V to +3v square wave signal. I need to maintain 1 volt per nanosecond (1 V/ns) on the rising edge. The reason he suggested the MOSFET is that they have an infinite current gain. I need 500 mA.
mcasale
Joined Jul 18, 2011
210
Just getting back to this. Sorry. I still don't know how you are driving the load, 500mA. Obviously, you need to do some level shifting, which a comparator will do. Then you can drive the gate of an n-channel MOSFET. 1v/nS is pretty fast. You will need to drive the gate pretty hard and fast. Note that MOSFETs do have input & output capacitances. Is there any spec on delay time from input to output, or is it just the slope that's important? A schematic would be helpful.
Ron H
Joined Apr 14, 2005
7,063
MOSFETs have ON resistance. Big MOSFETs have very low ON resistance, but they are very difficult to drive at 10MHz, due to the large gate charge/capacitance. Small MOSFETs are easier to drive. IMHO, If you need ±500mA at ±3V, you will need supply voltages that are higher than ±3V.
welkin87
Joined Nov 18, 2010
32
Thanks for help guys, I really appreciate it.
I don't have a schematic for the MOSFET amp I'm considering but I do have one for the opamp circuit the graduate student is currently using. I will upload it later today. The opamp is a TI OPA 2674. It has the exact specs that are needed for this project. That's why I have a feeling I'm not gonna be able to find any other better alternatives. Anything in the BJT department that might work? I'm searching as we speak.
gootee
Joined Apr 24, 2007
447
Incoming signal:
- 10 MHz squarewave
- 25mA (at most)
Needs:
It seems like you should be able to do it with an opamp amplifier (maybe the one he already has) that has a discrete high-speed power-booster amplifier inside its feedback loop, or after it.
You might be able to get some ideas from application notes AN-21 and AN-18, at linear.com. One of those has a 3000V/us amplifier (Fig 12 in AN-21) that should do what you need and one has one that does in excess of 1000v/us (Fig 3 in AN-18) that is almost there.
The LT1363/64/65 are 1000V/us single/dual/quad opamps, from Linear Technology Corp (LTC), linear.com. It seems like one or more of those and a discrete buffer/follower would do the trick (or help), too.
[Edit:] I suggest also looking at AN-94 at linear.com. Among other good tips, it mentions that the LT1818 (single) and LT1819 (dual) amplifiers can do 2500 V/us, with 70 mA output currents (Maybe you could just run eight or more of them in parallel?). Also make sure that you take a look at Appendixes B and C.
You will want to try to also model the parasitics of your conductors and components, in spice.
Here are links to over 20,000 spice models of components:
http://homepages.which.net/~paul.hills/Circuits/Spice/ModelIndex.html
http://www.elektronikschule.de/~krausg/Spice_Model_CD/Vendor List/
http://www.elektronikschule.de/~krausg/Spice_Model_CD/Mixed Part List/
[EDIT:] PRACTICAL SNUBBER DESIGN FOR OPTIMAL DAMPING OF RINGING:
You'll probably need the following, while trying to get the thing to work with 1 V/ns slew rates.
(This is pretty slick.)
GOT RINGING? I re-discovered a great way to easily determine the optimal value of R
(termination), or R and series C (snubber), to damp it out.
This is a very simple method for determining the parasitic capacitance and the
parasitic inductance of a resonance in a circuit or a transmission line or PCB trace,
which also gives you the characteristic impedance for the resonance, which is
everything you need to know to damp it, optimally.
This assumes that you have a ringing condition, already, such as might occur on a
digital buss or a transmission line or PCB trace, or in a switch-mode power supply or
even an AC-to-DC transformer/rectifier circuit. (If you don't have ringing and just
want to determine some of these parameters, I guess you could try hitting your
circuit with a pulse train until it rings.)
1. Measure the frequency of the spike resonance (ringing) voltage, using an
oscilloscope. (You might need a very-low-capacitance probe or probing technique.)
2. Add a shunt capacitor across whatever is ringing (or in parallel with the
parasitic capacitance) and adjust the value of this capacitor until the frequency of
the spike resonance/ringing is reduced by a factor of two. The value of this resulting
capacitor will be three times the value of the parasitic capacitance that is creating
the voltage spikes or ringing.
3. Because the parasitic capacitance is now known, the parasitic inductance can be
determined using the formula: L = 1 / [(2 x Pi x F)² x C] where F = (original) resonant
frequency and C = parasitic capacitance
4. Now that both the parasitic capacitance and inductance are known, the
characteristic impedance of the resonance can be determined using the following
formula:
Z = SQRT(L/C) where L = parasitic inductance and C = parasitic capacitance
5. The resistor for the terminator or for the RC snubber circuit should be sized to
the value of the characteristic impedance, and the capacitor should be sized between
four and ten times the parasitic capacitance. The use of larger (than 4X) capacitors
slightly reduces the voltage overshoot at the expense of greater power dissipation in
the resistor.
NOTE: An R alone would work to prevent or damp-out the ringing (or reflections, as the case
may be). But if power dissipation in the R would then be too high, a C is added in
series with the R.
Cheers,
Tom
