I am developing project of MOSFET switch that is going to be used as power switch device in application with 12S li ion battery. To keep power wastes in the minimum level, I have to provide the lowest possible RDSon value. In that application, the maximum voltage of battery will be at the level of 50.4V, so I've decided to use 60V MOSFETs. I really dont want to use 80V ones, as we know, the higher VDS breakdown voltage is - the more RDSon the MOSFET will have. But I am not sure, if this MOSFET will sustain any unpredicted, induced peaks of voltage (there is also BLDC motor on that power rail).
There may be situation, where this device have to get disconnected while full load due to "hard fault error" like overcurrent threshold exceeding.
1. Am I able to specify the value of overvoltage peaks from BLDC motor while this situation?
2. Is the BLDC motor driver protected from that kind of problem - disconnecting power in full load?
3. Am I able to protect this 60V MOSFETs from unpredicted, induced overvoltage breakdown peaks?
Pseude electrical schematic:
