MOSFET overheating in audio LED controller circuit
R.Gregory
Joined Feb 24, 2017
Greetings,
I built a circuit which uses line-in audio to control a white LED strip using a MOSFET. the MOSFET overheats when the LEDs are illuminating the brightest i.e. when the music is the loudest. Is it possible the LEDs are drawing too much power? i took the original design form this post:
https://www.allaboutcircuits.com/projects/make-an-analog-sound-reactive-led-strip/
I removed the filter right after the input and also removed the switches that control multiple colors as i'm controlling a single color strip. i also swapped out the 47k resistor for a 100k pot.
I'm driving this strip:
118", 9.5 watts per foot, 12vdc
http://www.ecolocityled.com/product/supreme_white_led_strip/led_strip_white
with this power supply:
output: 12v, 100w
https://www.amazon.com/gp/product/B007K4XZPG/ref=od_aui_detailpages00?ie=UTF8&psc=1
Any tips are welcome!
Gregory
#12
Joined Nov 30, 2010
18,224
1) Removing the input filter is wrong. Humans can't see an LED flashing at more than 30 times per second. Allowing the audio signal to blink the LED 10 or 20 thousand times per second accomplishes nothing but making the mosfet spend half its time in transition between on and off, which is when the heat builds up.
2) That 100 ohm resistor from gate to ground is wrong. The op-amp can output V+ minus 1.5 volts. That puts 3.5 volts on the mosfet gate and that seems OK but it also calls for 3.5V/100 ohms = 34 ma.
Look at page 5, bottom left graph and see that the opamp is losing about 6 volts while trying to deliver 35 ma and it only has 5 volts to start with! Therefore, your gate drive is being wrecked by the 100 ohm gate resistor. Change it to at least 1000 ohms or 2200 ohms.
#12
Joined Nov 30, 2010
18,224
Holey Smoke! The Orange Team allowed that to be published on AllAboutCircuits?:confused:
Without checking to see if it would work or why he specified a Military Grade amplifier chip?
I hope they didn't pay him much.:mad:
Sensacell
Joined Jun 19, 2012
3,787
Totally cringe-worthy.
A $10.00 opamp to flash some LED's.
The schematics look like they were drawn by an amphetamine-fueled squirrel.
Another brilliant bit of AAC editorial.
R.Gregory
Joined Feb 24, 2017
Much thanks for the quick thorough response. I've swapped the 100k resistor for a 2.2k and the MOSFET shows little to no signs of heating up. The LEDs are responding just fine.
I am using a graphic EQ before the circuit to have more control over what frequencies are allowed. Do you think the original filter within in the schematic is still necessary?
The big question i'm wondering is after the exchange of the resistor is this a worthwhile design or should i start from the drawingboard? Ideally i'd like a system that i can keep in an enclosure safely and use without concern.
R
#12
Joined Nov 30, 2010
18,224
My EQ only goes down to 31.5 Hz. It sure would look funny with one knob up and nine knobs down!:D
Besides, it's expensive and still too much bandwidth to use a graphic equalizer for each LED blinker so I wouldn't do that when I can design the EQ out with a resistor and a capacitor.
There are a lot of things I wouldn't do besides designing it so it won't work, like using a Mil Spec chip, a dual amp when you only need one, a 20 volt mosfet in a 12 volt circuit, or a 100 AMP mosfet to control 100 WATTS...unless its way cheap.
I did a slightly improved version by eliminating the 5V regulator, changing the input impedance to make the capacitor smaller (cheaper) and lowering the feedback impedance so it doubles as a gate resistor for the mosfet. If I was getting paid, like the guy who did the original drawing, I would change the op-amp to a higher impedance version to further decrease the size of the input capacitor and reconsider throwing away 90% of the input signal, only to put it back in with op-amp gain.color organ.png
So, yeah, start over. Wrong amplifier chip, wrong mosfet, wrong input impedance, wrong feedback impedance. The only thing he got right was the frequency range and you immediately peed in that.:eek: Bad beginner!:D Worse designer.:( Maybe you can live with the input filter now that I've improved it down to a way smaller capacitor.;)
