Who are u?again you also have to check if your transformer is in good condition. you know a short in the trans. can cause that especially at the secondary side of the trans.
A load can be anything drawing current. A blown IC, transistor, capacitor etc can all become loads draining current.No load, nothing nada.....just open circuit voltage is OK, even a light load cause the voltage to drop, when removed, voltage comes back slooooooooooooooowly.
The one where I designed power supplies for 30 years. Let me repeat what I said:Haven't u been reading..
Which planet are u from ?
And add this: your post is the electronic equivalent of:A regulator that only "works" no load often means the feedback control circuitry is OK but the power device(s) are blown. They pass enough leakage current to put the output at the right value unloaded but fail anytime any added load is required.
I guess now you make sense to me.You probably have an off-line switcher designed based around a half bridge topology using dedicated ASICs unique to the manufacturer. When a converter blows and transistor junction get punched, it often puts high voltage onto the low voltage drivers and/or control circuitry. In short, it can blow almost anything or everything. That's why a low wattage power supply is considered a disposable item. Even if you had the schematic, the "repair" procedure is to change every part that could have been hit and that typically costs about 3X what a new replacement P/S does.
You can split it here: http://foxyutils.com/splitpdf/i have yr manual but cant upload it because the filesize is too big-the pdf limit here is 5mb???the file is 6.1mb
Does not even come close to what I have..mateis this yr set??
