This is indeed a peculiar problem. Trying to debug without a scope or at least a logic probe is a challenge.
The supply to the processor board is certainly a possibility. I've been assuming some sort of off-the-shelf development board that would have all the necessaries in terms of decoupling.
"Grounding" is often at the root of problems like this, which is why I suggested the tests a few posts back.
With regard to fast-rising voltage, nasty noise on the LED power supply would be a possibility, but it seems very unlikely to me since different supplies have been tested. It is the sort of thing that might arise due to connecting wire inductance with multiple LED strings e.g. long wire to LED supply, one string turns off leaving the inductance of the wire to discharge through ... something. I've seen a bipolar 555s without decoupling generate 15 to 20 volt spikes at their Vcc pins when running on 5 V with less than metre of wire to the power supply, so a very big spike here wouldn't surprise me. But the problem persists with one string.
Nutshell - Can you post some photos of your setup?
