OK, you bought a kit.John,
As mentioned, I didn't design this, so I do not know the theory behind the decisions made to have only one resistor, 20 FETs or anything else. As for a schematic, all I can do is to post a picture of the board. Let me know if you would like me to.
Contact the kit manufacturer. What resistor does it recommend? Maybe, ask for a refund under warranty.However, all I am really interested in is what goes into choosing a gate resistor. Do I simply choose the value the manufacturer lists under their test conditions, or is it even that important?
While it is true the final value is determined empirically, it is not entirely guess work. There are good starting points, and with a scope, you can easily see when oscillations are damped. Circuit inductance and capacitance for each gate affect the final value. One thing to remember is that a single, 20-ohm resistor feeding the gates of 20 power resistors is equivalent to a 400 ohm resistor feeding one, at least in terms of turn on time. It will be relatively slow.Most of the research I have done (including reading several documents from IR) suggests that the resistor is more or less guesswork.
A single 20K gate resistor feeding 20 power mosfets is like feeding one with 400K. They will turn on, eventually, but may burn up first.Honestly, I'm leaning towards leaving the 20k gate resistor in for the new mosfets. My pcb is already designed and built, so I am now aiming to make the best of it.
Yes, some people use just a diode, no resistor, in the turn-off circuit. That design is shown in the IR application note.As for discharge time, there is a diode and resistor parallel to the gate resistor that is there to control turn off times. After reading the second article you posted, I see how important turn off can be when dealing with parallel mosfets. It seems to me that you would almost not want any resistance at all on the diode, to allow them to turn off even faster since miller charge can tend to keep the quicker to turn off FETs to stay in linear mode for longer, creating heat.
In sum, I think it is a mistake to use a single gate resistor. If you consider the discharge time and hence maximum current, my gut tells me that 20 mosfets is overkill in this application. Since they are in parallel, you could try using just 5 to 10 for starters. If the PCB isn't drilled for the resistors, you can consider an off-board construction technique like this:
We have not discussed what you paid for the kit/design. I hope it was not much, as it does not sound like a well engineered design considering its use of a single, high-value gate resistor. At some point, you may decide to write it off as education.
The idea of using mosfets for a CD welder occurred to me too, as one might be able to control the welding cycle(s) better. For example, some CD welder vendors recommend using two pulses, one to clean and one to weld. That could be done easily in theory with mosfets; however, I would want to see actual results obtained under objective, controlled conditions before making a design to do that. I have not seen any such data. If you use a single scr (or mosfet), you could always just fire it twice. That's what I do. The additional amount of time to assemble a pack for a hobbyist is insignificant.
Finally, 10 mil Ni seems a bit heavy gauge for battery tabs, but that is just a first impression. I suspect 15V from audio (?) capacitors may not be sufficient for that thickness. Remember, a lot of factors will limit the maximum current you can achieve, not just the mosfets or size of cable.
John
