Hi, I want to use mosfet to replace the relay I use for my motorcycle turn signal light. I use relay to connect directly from the battery so the light can be brighter and lit more stable (not flickering as the engine rotate). So the relay connected to the flasher and the battery. I tried to use a combination of n (IRFZ44NPBF) and p channel enhancement (IRF9540NPBF) mosfet paired with 10K resistor each but the LED stays on and not blinking as it should when I use a relay. Any suggestion what mosfet should I use so it would blink according to the flasher?
