MOSFET footprint on PCB
pjreijiri
Joined Aug 19, 2015
116
Hello everyone,
I am designing a PCB and I want to use an IRFP4468 mosfet.
It has a heatpad on the back. I know how to make the 3 through holes for G, D and S. but how can I position a heat pad on the PCB for it?
Since the mosfet needs to be bent, how can I know where to position the heatpad in relative to the holes?
Since we are on the subject as well, do you have an idea about diodes? What is the minimum distance between the 90 degree bend in the leg and the body of the diode?
bertus
Joined Apr 5, 2008
22,947
The TO247 housing is normaly mounted on a heatsink.
The fet is mounted on the edge of the PCB so the fet can be bolted to the heatsink.
Bertus
ScottWang
Joined Aug 23, 2012
7,503
Please upload your circuit and PCB layout to the forum and compress them to a clear resolution as 800x600 or 1024x768 .jpg file.
ronv
Joined Nov 12, 2008
3,770
Hello everyone,
Here is a link about it.
http://www.irf.com/technical-info/appnotes/an-1031.pdf
As far as pad location goes, you need to use the mechanical diagram to calculate it.
