MOSFET Fall time Increased when switching at high frequency.
Tankesh singh
Joined Jan 21, 2017
19
Hello Everyone,
I am facing a problem to switching the MOSFET. I attach the circuit detail. i am switching the resistive load(12v bulb) at 27Khz at 47% duty cycle. when i do it fall time is increase which change the duty cycle. tell me how can i perfect switch my circuit.
Note : 1) fig. 1 show the square wave which peak volatge is arround 12v (47% duty cycle) is applied at gate of mosfet.
2) fig. 2 yellow color show Gate to source waveform.
3) fig. 2 blue color show drain to source waveform.
38,881
You need a lower impedance driver for the MOSFET gate, to rapidly charge/discharge the gate capacitance.
What is driving the gate now?
dl324
Joined Mar 30, 2015
18,480
The problem is likely in the circuit driving the gate. Post a schematic that includes the gate driver.
Tankesh singh
Joined Jan 21, 2017
19
circuit is based on sg3524. which may capable to drive mosfet. i change the trasformer to load and also change R and C value to get desired frequency.
38,881
The outputs of the sg3524 are single NPN transistors (below) and you are attempting to use them as emitter-follower outputs to drive the MOSFETs, but there are no emitter resistors.
You thus need to connect the collectors (pins 12 and 13) directly to 12V and move the 2kΩ resistors to between the emitters and ground (pins 11 and 14), to rapidly pull down the MOSFET gate voltage when the transistors turn off.
If that isn't sufficient, then you will need to add a buffer driver to each output.
Tankesh singh
Joined Jan 21, 2017
19
thanks crutschow. I add a 10uF capacitor between emitter and gate of Mosfet. falling time is decrease when i add a resister(2K ohm) between emitter and ground but not so much. when i decrease resistor value falling time is also decrease. so i add 68ohm resistor thats make a perfect square wave with falling edge but thats create a new problem resistor is staring heating and voltage across gate is decreased 12v to 9.2v.
