mosfet current limit circuit
ilginsarican
Joined Jul 13, 2017
147
I use this circuit to limit supercap charging current.There are 10 supercaps(each one is 300F 2.7V) in series.
According to this circuit, the maximum current that capacitors draw is about 1.3A.
Although I use a cooler, p channel mosfet(Q6) is getting very hot.(160C) because it is in active region.
To solve this problem I've reduced the value of R3.
I thought that if the mosfet approaches the saturation zone, it will heat up less.
But the liimitted current did not changed so overheating problem continues.
ericgibbs
Joined Jan 29, 2010
21,580
hi,
As you say with only Vgs= 2.6v the FET is only just On, I make it around 36Watts dissipation, for completely discharged caps. == 10F
How long is the full charge period.?
E
ilginsarican
Joined Jul 13, 2017
147
hi,
E
It takes 15 minutes fully charge.
hi ilgin,
This is a close approximation to your circuit.
The charge time approx 250secs, max heat in MOS 33 Watts
E
Hi Eric,
hi ilgin,
E
Hi Eric,
It takes 15 minutes fully charge,I use supercap,total capacitiy is 30Farad.
The capacitors draw 1 amp for 15 minutes.
How do you calculate power dissipation?
The mosfet is not fully open,because of that it is getting hotter than fully open situation.
ericgibbs
Joined Jan 29, 2010
21,580
hi,
Using Q=C.V , where Q= I.t , gives.... t= (30* 28v )/1.2 = 700Secs.
Re simulated with 30Farad
You say 900 Secs at 1A.
E
EDIT:
Have you considered 'burst' control from the MCU drive, ?
How quickly must the cells be recharged.??
ronv
Joined Nov 12, 2008
3,770
You could use a power resistor to drop some of the voltage and thus some of the power in the FET.
38,844
Besides the options that Sensacell and ronv mention, you could also use a better heatsink (possibly with fan cooling) for the MOSFET.
You say you use a "cooler" but what does that consist of?
BobTPH
Joined Jun 5, 2013
11,659
A current controlled buck converter is the only way to go, IMHO.
The bang bang style converter would be appropriate.
Bob
