hi folks, i'm obviously being lazy here but figure i'd risk members wrath (and save killing product) rather than read through posts for a week, apologies in advance.
could someone with knowledge please tell me the simplest way (circuit) to take the signal from a signal generator and feed it into a transformer.
i want to experiment with ferrites/windings etc etc and so need to amplify/buffer the signal from the generator to the experimental transformers, which will be all sorts of inductances and all sorts of reactances.
the frequency will be below 60 khz.
equipment i have is: a 0-30 bench top psu, a gwinstek gfg-8215a signal generator, a scope and multimeters etc
i have some irf540n mosfets, so would like to use those if posssible.
i was initially at least going to keep the signals to single sided square wave.
i’ve never used mosfets and have heard they need different setup/biasing than bipolars and am scared i’ll kill the few semi’s i have before i get it right. thanking you in advance for your help.
