MOSFET Behavior
Dobbies
Joined Dec 13, 2017
29
I was experimenting with an IRF840 and connected a small load transformer inline from battery 12V+ to the Drain pin and the Source pin to 12V- leaving the Gate pin completely unconnected. To my surprise the MOSFET started to get warm.
Could someone please explain what is happening here because when I connected the Gate pin to 12V-, it stopped conducting.
Many thanks
ericgibbs
Joined Jan 29, 2010
21,439
hi,
An Open circuit MOSFET Gate can assume a 'high' state, so the MOSFET will be partially On.
As the MOSFET is not fully switched On, its dissipation will be high.
E
bertus
Joined Apr 5, 2008
22,923
In some schematics you will find a resistor of 10K to 100K from the gate to the source mounted.
This will avoid the mostfet to be conducting partially.
The gate can be seen as a capacitor and the resistor will discharge the capacitor.
