More gain needed for Velleman VU Meter
Ian0
Joined Aug 7, 2020
13,311
I'd swap the outputs, to that the first one goes to the audio and the buffer goes to the VU meter. Each op-amp will add some noise and distortion, even if it's only a tiny amount, better to have the cleanest signal going to the audio.
rpschultz
Joined Nov 23, 2022
851
well ok. I thought since the VU meter already had an op amp it didn’t need another one. But I see your point.
Audioguru again
Joined Oct 21, 2019
6,826
The output of your first opamp can drive all the the rest of the pedalboard and the second opamp is not needed.
The input resistance of your first opamp is only 100k but it can be much higher.
The opamp in the VU meter is a "precision rectifier" with a small amount of gain. It rectifies the AC audio into DC and its opamp cancels the forward voltage of the rectifier diode.
38,932
Technically, since the diode is in the feedback loop, its forward drop is reduced by approximately the open-loop gain of the op amp (which typically is very high), effectively making the forward drop negligible.
Ian0
Joined Aug 7, 2020
13,311
R2 is not usually included in a precision rectifier circuit.
