Monostable 555 timer problem
ScottWang
Joined Aug 23, 2012
7,504
Try 100uF and 56K or 47uF and 120K.
If you check the circuit wiring is correct and it still doesn't works then you have to use the CMOS type as LMC555, TLC555
Quark.
Joined Mar 24, 2017
5
I'm already using the TLC555, I will try with other resistor and capacitor values.
Here's the schematic I'm using:
bertus
Joined Apr 5, 2008
22,968
What are the specs of the used led?
The TLC555 can source only 15 mA, see the maximum ratings list:
When the led has a voltage drop of 2 Volts and the supply is 5 Volts, you are expecting to have 30 mA in the led.
Bertus
dl324
Joined Mar 30, 2015
18,433
Caps larger than approximately 100uF aren't recommended because they're too leaky and tolerance is typically 20% or more. This graph shows other combinations you can use to get 6 seconds:
Quark.
Joined Mar 24, 2017
5
Thanks all for the suggestions, I don't have time now so I can't test them.
But after a few tests, I dicovered that capacitor 1 never charges, it stays at arround 1.5v. If I disconect pin 7, the capacitor charges to 5v and the led turns off.
jr_73
Joined Jan 25, 2017
Yes, that cap is the main problem. I've even had 1 uF electrolytic caps that had such high ESR that they wouldn't charge. High-quality caps help immensely.
But after a few tests, I dicovered that capacitor 1 never charges, it stays at around 1.5v. If I disconnect pin 7, the capacitor charges to 5v and the led turns off.
Moderator's Note:
The commercial does not allowed on this forum, please don't do that, otherwise you will get ban as spammer.
dl324
Joined Mar 30, 2015
18,433
The problem is that you don't have a pull up on the trigger input (as pointed out in post #9) so it can rise above 1/3 VCC, so the output stays high.
Quark.
Joined Mar 24, 2017
5
I added a pull up resistor and tried different combinations of capacitors and resistors and still didn't work.
Is possible that I have a defective TLC555 or I broke it somehow?
Also, I made a astable circuit and didn't work, however I made Schmitt trigger and it worked fine.
bertus
Joined Apr 5, 2008
22,968
Do you still use the 100 Ohms resistor for the led?
It should be higher than 330 Ohms to avoid overloading the TLC555.
Bertus
dl324
Joined Mar 30, 2015
18,433
The device is static sensitive, and you could have broken it. But if it works in some other circuit, damage is unlikely.
Post the complete schematic for a circuit that didn't work and give us the relevant voltages in the circuit.
EM Fields
Joined Jun 8, 2016
578
So I tried to make a monostable circuit with the 555 timer, following this guide https://www.allaboutcircuits.com/tools/555-timer-monostable-circuit/, to turn on a led.
I used a 2200 μf capacitor and a 2.4 kΩ resistor, so the led should stay on for 6 seconds, but when I connect the power (5V), the led is on and never turns off, even if I activate the trigger.
What is wrong?
Possibly, the leakage current through the huge cap is hogging the current and not allowing the input to rise to a detectable level.
