Hello-
I have a switch that fits in a blank in my Toyota dashboard that I'd like to use to light an LED light bar for my truck. The switch is a momentary switch (I believe) and has the following 6 pin outs (Switch Voltage +, Switch Voltage -, Switch Illumination +, Switch Illumination -, Switch Indicator +, Switch Indicator -). I hooked up my multimeter ends to the Switch Voltage + and Switch Voltage - pins and it only beeped for continuation when I was holding the switch. I would like to use this switch to turn on and off a 11.3A, 13.8V light bar at the front of the truck. I've read about 555 timers, flip flop relays, latching relays, but I'm honestly just confused. I'm a civil engineer and this just isn't something I have any experience with, but having a logical mindset, I can usually figure things out. Ideally I'd like to buy something that I could just wire in/out of between the switch, light, and battery, not against making something, but that's probably out of my skill set. The switch is internally lit when the headlights are on and I could tap power from a neighboring switch for that. The switch also has an indicator light that comes on when the light is on that I'd like to have operational as well. I tried to illustrate on the attached PDF, but I may be way off. Any help is certainly appreciated and I'll follow up with my results.
Thanks,
Brian
Thanks,
Brian
