How is that?You’d need the 5 pin relay unless you don’t care if you’d be drawing extra current to keep the lights off.
If he connects to pin 87 (NC), then to turn the lights off, current must flow through the coil. I’d guess the lights would be off more than on, which would draw “extra” current.How is that?
I’ll take your word for it. I admitted that I was unfamiliar with pin numbering. The source from my research (likely incorrect in light of your post) said that pin 87 was NC.Pin 87 is NO.
Sorry for the confusion. With a 5 pin relay, don’t connect any thing to the NC contact.So in the 4 pin relay, 87 is NC, I need to get a 5 pin relay and connect to 87a which is NO and then don’t connect anything to 87?
You can check which is what with a multimeterAppreciate it. I guess there are 4 pin relays in both the NC and NO variety. I’ll grab the 5 pin and connect to the NO.
Though there's been some confusion about NO and NC on pin 87, I think your drawing is correct.Based on your sketch, would the attached be correct?
I would tend to believe pin 87 is NO. What's the use of having a fan, fuel or horn relay (for example) that you have to turn the relay ON to turn those devices OFF? 30 & 87 should be open at normal resting mode and only conducting when pins 85 & 86 are powered. That's what a relay is supposed to do.So in the 4 pin relay, 87 is NC, I need to get a 5 pin relay and connect to 87a which is NO and then don’t connect anything to 87?
@djsfantasi this ended up working. Thank you. I’m wondering what keeps the higher amperage current from running through the module and burning it up? It looks like the 11.8A of the light bar would try to go through the module rather than around.IMHO, I think the idea presented in post #6 is the best one. You can use the module to operate this relay (which is rated for 15A), which then can switch the light bar on/off with successive presses of the pushbutton. Everything is wired as in this diagram:
The module is totally isolated from the 11,8 amps by the relay. The current for the light bar is switched by the relay contacts (which are rated for 15A). None of that current can get to the module. The contacts are what carries the current “around” the module.@djsfantasi this ended up working. Thank you. I’m wondering what keeps the higher amperage current from running through the module and burning it up? It looks like the 11.8A of the light bar would try to go through the module rather than around.
