Modify an existing four bit arithmetic unit that can add and subtract two EIGHT bit binary values
mikebravo
Joined Aug 13, 2019
Using the digital work simulation package, modify the existing circuit I have made which only supports four bit addition/subtraction to support eight bit binary add/sub.
https://imgur.com/a/Kusw1Z7 - this is a link to a screenshot of what i have made thus far within digital works application. The circuit on the right is currently only able to support two four bit binary values being either added or subtracted with a press of the button at the top. what i want to do is support two signed eight bit binary values instead.
ericgibbs
Joined Jan 29, 2010
21,584
hi Mike,
Welcome to AAC.
As this is a Homework question, we would like to see your attempt at answering, we can then help you.
E
mikebravo
Joined Aug 13, 2019
https://we.tl/t-gzkd1oicBy - here is a link to the .dwm file. You can open it within digital works application (which can be found here - https://en.freedownloadmanager.org/Windows-PC/Digital-Works.html ). Any help is massively appreciated.
