Mixed Signal Simulation Error
Nomi 1114
Joined Dec 4, 2017
124
Hi, hope you all are fine. here, i wanna confirm one query that i simulated one circuit in Altium Designer 16.0, but i found one error, and i am unable to understand what does its mean ? the error statement is like as ;
"Net C2_1 has no driving source "
please reply me as soon as possible !!!
danadak
Joined Mar 10, 2018
4,057
Its telling you a component/wire/net has no signal/wire attached to it.
Normally one views schematic at larger magnification to see if
your connections look OK. And/or you delete the connection and
place it again.
Regards, Dana.
TeeKay6
Joined Apr 20, 2019
572
place it again.
Regards, Dana.
Or it could mean what it says: The net has no driving source connected; the software recognizes that by the way component pins are defined (in, in/out, out, PS, etc) in symbols. So there may be connections but none of them is recognized as a driver (i.e. out, in/out, ground, PS).
Nomi 1114
Joined Dec 4, 2017
124
place it again.
Regards, Dana.
Thanks Dear Dana !!!
