Miniature Signal Relay Not Switching States
gerty
Joined Aug 30, 2007
1,305
The first thing that I can recommend is make sure you are putting the voltage to the correct relay pins, should be 1 and 12.
edit: How are you checking to see if the relay changes state?
marshtech
Joined Nov 2, 2017
8
I have PN: EC2-3NU
I am supplying coil voltage to pin 1 and 12.
I am checking continuity between pins 3 and 4, for example. That contact should open when energized.
LesJones
Joined Jan 8, 2017
4,511
What resistance reading do you get between pin 1 and pin 12 ?
Edit Ignore this post. The question has been asked in another post and answered.
Les.
mcgyvr
Joined Oct 15, 2009
5,394
You shouldn't need a meter as these make an audible click when energized..
Please try reversing 1 and 12..
Its unlikely that 3 are bad.. BUT its possible..
The diagnosis is not rocket science.. If you know how to apply power and check continuity and thats not working then they are all bad..
marshtech
Joined Nov 2, 2017
8
power source is a 0-30V 0-5A power supply. it would seem odd that all 3 are bad. I'll give it one last shot later on today.
AnalogKid
Joined Aug 1, 2013
12,126
Does the supply have a constant current limiter function? If so and it is turned all the way down, the supply might not be making enough energy for the coil.
ak
marshtech
Joined Nov 2, 2017
8
The power supply has the constant current limiter. I'm pulling the required current to be around standard operating power per the datasheet which is approx 140mW
