looking for miniature Audio connector
LAOADAM
Joined Nov 21, 2018
956
Hi all.
The normal Audio connector like 2.5/3.5mm socket is kind of too large for a small area, what can be if just use like 1.25mm plug?
thanks for help.
Adam
28,371
There are several considerations for audio connectors aside from size. One consideration seldom mentioned is durability. How long will it last in normal use? Some 2.5mm connectors are very fragile and it does not take much lateral force to bend or break them. That also applies to more than a few 3.5mm connectors.
There is also the question of being able to even attach the connector to the wires it would be used with.
So "what is the application??" for a tiny connector? And why would I ever even consider using one??
panic mode
Joined Oct 10, 2011
5,295
small size may be desirable but you still did not answer what the application is, what the electrical specs are as well as how many times this is to be be connected/disconnected. connectors have rated number of cycles and for some it is low. you can connect stadium speakers through a headphone jack but this is not going to work.
28,371
I am unable to see whatever is diagrammed clearly. Besides that, the term "Controller radio" means nothing at all because it is so very generalized. AND why would a tiny radio include an analog meter????
LAOADAM
Joined Nov 21, 2018
956
basically just : 1 pc ESP32 kind of controller or others see size; + 1 pc TEA5767 module, it works, the picture found online, guess the meter is for testing.
