First of all.
There are few component value errors on the schema. Will correct them as per the prototype.
Just finished the PSU regulator PCB and the Driver.
The Regulators. I am using a LM317T to get the Aux 12V rated at 1.5A.
For the 5V, I am using a sanken 5V switching Reg. rated at 3.5A.
Plenty to go around.
The supply Reg's are working, for the time being I will be using my Big daddy PSU to get the 24VDC.
The Driver I prototyped. Haven't tested it yet, fuses are not yet installed. But will be tested with them.
I got a little confused abt the NFB resistors, some doc's say that it shud be a non inductive type. Ran around whole night to get the value for 3 Amps, which if my calculation is correct rounds up to 0.17Ω at 2W.
I ended up with nichrome wire, since I have a mili ohmmeter. It was easy to cut the value.. I labeled the NFB. I hope this works.
Will update after testing.....
