Mimic a landing light
MXPlthk
Joined May 31, 2023
10
I am trying to figure out how to use 2 changeover relays, 2 NC momentary pushbuttons and 2 NO pushbuttons to mimic a landing light. I know it is more practical to use a latching switch instead but this is just an experiment.
Can it be done? Any help would be appreciated.
MXPlthk
Joined May 31, 2023
10
For those of us who do not understand landing lights, what are landing lights and what kind of behavior do you want from them?
It’s just a regular light that can be powered on and off by 2 switches. For e.g. a light that has a switch on the ground floor and the first floor
Alec_t
Joined Sep 17, 2013
15,156
Can we assume the relay coils are rated for continuous operation, powered by mains voltage?
Are the relay contacts SPDT or DPDT ?
MXPlthk
Joined May 31, 2023
10
Yes, the relay coils are rated for continuous operation and is powered by mains voltage. The relays are DPDT
38,819
You only need one relay.
Below is the basic relay latching circuit:
The lamp, of course, is in series with the C-D set of contacts.
You would need to run two wires between floors for the push button connections.
Edit: Revised schematic to show both sets of pushbuttons.
MXPlthk
Joined May 31, 2023
10
Can it be done if you were to use 2 relays and 2 Normally Closed momentary Pushbuttons and 2 Normally Open pushbuttons?
MXPlthk
Joined May 31, 2023
10
Yes, but why would you want to use 2 relays when all you need is one?
that’s a given brief. Which is 2 relays need using. Just using one relay would have been a lot easier in my opinion.
MXPlthk
Joined May 31, 2023
10
Yes it is. I’m confused about adding the 2nd relay. i don’t know how to get it so that the light can be turned off using 1NC or 2NC.
MaxHeadRoom
Joined Jul 18, 2013
30,813
My thoughts were the same, wondered what the application was?
Landing light to me are the double/horizontal bank of lights that a pilot uses when lining up his landing angle approach.
They indicate if coming in too low or too high, i.e. decent angle. :cool:
