Might be a stupid question to most...
kuera
Joined Aug 17, 2012
39
but I was wondering.
I know how to calculate what resistor is needed to drop current to an LED if the source voltage is higher than that of the LED with the supply - (led voltage) divided by the required current. But my Voltage source is the same as the LED needs, thing is its a 1 watt LED (at 3.6 volts) but instead of drawing the full 270 mAmps I only want to to draw about 150, how would I go about working that out or what is the resistor I would need for it?
Thanks in advance.
35,207
It is not possible to calculate the resistance required without knowing the I-V characteristics of the LED (which is non-linear).
Do this experimentally by trying different values of resistances until you get the desired effect.
Let us know your results.
kuera
Joined Aug 17, 2012
39
It's a 3.6 volt, 1 watt LED (about 0.270 amp)
so yeah I see what you're saying. I'll just mess around ^^ thanks
wmodavis
Joined Oct 23, 2010
739
To reduce the current through the LED you need to reduce the voltage applied to the LED. A resistor would do that or any of a myriad of other possibilities.
