midi hi hat controller using a FSR.
seayaker
Joined Jan 27, 2009
98
I need to write an Arduino code for a hi hat controller, I have a pedal that works with a commercial drum pad assembly and it uses only 1 FSR.
The pedal itself triggers 2 different midi notes. One when the pedal is tapped down and another when it's tapped down but quickly released. The pedal also controls which one of 3 notes is played on a designated pad. So if the pedal is up it plays note #... pedal half way note #... pedal down note #... So whatever midi note is assigned will play the sample that's assigned to that note.
Anyone know of an example of this or how this could be done?
